1968 Swing Away location of interior vacuum canister
Started by bigdog01, February 16, 2019, 05:17:44 PM
bigdog01
Does anyone have a picture of where the interior vacuum canister mounts?  I have everything installed, but cannot figure out where the interior canister mounts.
Right below the ashtray. You will find a locator hole and a mounting hole
bigdog01
Same area as the fog lamp and defog switches mount?  I will look again, it seemed to get in the way of the switches.  I seen what looked like where it would go, but the cruise control switch is mounted there.
bigdog01
Thank you.  It will look so much better mounted than just hanging there.
And it will work better, since it needs a ground  🐋
Chris Thauberger
Previously owned:
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
68stangcjfb
Is that lineman's tape supposed to be on the steering column holding the turn signal switch wiring cover?
bigdog01
The linemans tape solves a second problem.  My cover keeps falling off.  Thanks
68stangcjfb
#12
Was it used on the saddle interior and cars without tilt away? Seems like it would stick out like a sore thumb on those cars
Corey Bowcutt
I just finished installing the Tilt-A-Way stuff in my car.  I took these pictures of a car at a show a few years ago and they helped me out.  I hope they help you.
Corey
