289 Cobra/Lightweight Galaxie Aluminum T10L transmission - new
Started by acman63, February 24, 2019, 08:57:13 PM
acman63
289 Cobra/Galaxie Lightweight T10L aluminum transmission  .  Transmission is new and ready to go.  We used  one of our last  concourse aluminum  case and tails  which we had made awhile back and saved it for doing a  complete transmission .  These parts were made using nos originals to make the tooling and were beefed up in areas inside that were always an issue with original transmissions . We have accumulated some very hard to get NOS 2.36 ratio nickel alloy parts to build this.  Includes  all  possible NOS original high nickel parts including nos  26 tooth  - 10 spline main drive , close ratio cluster , 1st gear, 2nd gear, 3rd gear - .   Also includes super rare  NOS Ford original 28 spline main shaft . It took me 5 years to accumulate these rare nos  parts.  The build includes clearancing gears for better oiling in high performance usage , New Premium Severe Duty bearings.  Racing cutback synchros with premium blocking rings.  All new small parts and bushings .  Blueprinting and assembly by the best T10 guy I know . When have you seen basically an all new Transmission?  This type of transmission was used in 289 Cobra and lightweight 1963 Galaxie.  we will provide the proper crankshaft pilot bushing depending on application.  Transmission will be shipped in a custom wood crate with padding inside ..    $10,995 FOB  Green Bay  920 434 3645  jim@shelbyparts.com   - give us a shout
SAAC Concours Chairman
acman63
