67 Shelby headlight wiring harness?
Started by T-Bone68, February 27, 2019, 09:34:47 AM
T-Bone68
building a 67 GT500 tribute and buying all new wiring harnesses.  For the front headlights, can anyone answer do you need the 67 with Tach, with foglamps... or the 67 with Tach, without fog lamps?  Or does it even matter?
Sorry, should be able to figure this out, but haven't yet and about to order all wiring.  Any help appreciated.
  I don't know but don't forget the white scotch splices.
No fog lamps on a 1967 Shelby.
If you need a quote on wiring, please send me a note
Coralsnake68@hotmail.com
Quote from: T-Bone68 on February 27, 2019, 09:34:47 AM
Sorry, should be able to figure this out, but haven’t yet and about to order all wiring.  Any help appreciated.
tach yes - fog lights no.
Quote from: roddster on February 27, 2019, 10:52:00 AM
See "1967 Shelby GT350/GT500 Master Assembly Manual" page 19 for diagram of how to splice-in grille mounted high-beam lights with connectors mentioned above.  Pig-tails for doing this are available from a number of sources as posted in reply #2 - Pete is one.
T-Bone68
Thank you all for your quick advice.  Trying to keep as close to original wiring as possible so years from now I can refer to Ford/Shelby docs to troubleshoot.
I have the Master Assembly Manual... I'll check out pg19.  Thanks!
John
If you are running a FACTORY tach cluster all three related harnesses are different. The Alternator, under dash harness and Engine harness that comes from the firewall and runs to the solenoid and the under dash harness are tach only.  The wiring for the inboard or ourboard lamps were white Scotch Locked onto the headlight extension plugs.
        -Keith
Bossbill
Quote from: 1967 eight barrel on April 08, 2019, 02:34:09 AM
        -Keith
I've only seen them attached to the main harness. If ONLY they had hooked to them to the extension harness or created an intermediate plug.
Fixing the main harness when things go wrong at the connectors is really painful.
70 B302   6/6/70  0T02G160xxx
Bill, the high beam extensions are on  outter headlamp extensions in my case.
        -Keith
T-Bone68
Thank you all again for your help.  Just double checking one additional detail... What color should the head light plugs be, red or brown?
I'm coming to the conclusion I should replace the headlight harness on my 67 GT350 #2246.  Found at least one cut wire and many suspect cut and re-taped connections.  My car has the red plugs as pictured, but I also know it went through a not 100% perfect restoration somewhere in the 80/90s so wouldn't be surprised if the wrong harness was used.  I noticed a pic of 67 GT350 wiring harness in Greg's book also shows red plugs.  Alloy Metal Products reproductions have brown plugs.  So, short version... just asking if the brown plug is correct before I put it in my car.
John
GT350Nick
Coralsnake did a great job on my headlight and center light wiring harnesses....highly recommend
The Going Thing
That's because the plugs come in both colors.
