1967 428PI - Shelby GT500 Engine - For Sale
Started by tyfaciane, February 06, 2018, 10:54:28 PM
tyfaciane
I have a beautiful recreated/restored 1967 428PI Shelby GT500 Engine For Sale
(I uploaded both pictures - before and after I removed the background - so you can see this is a picture of the actual engine that you will receive)
This is a good starting point for a highly detailed, show car quality engine.
The parts I collected - the hard parts (block, crank, heads, intake.... the rods are C6AE-C 3/8" ARP Bolts????) to build this engine are all RARE and EXPENSIVE parts.
The engine actually includes the power steering pump, (all 67 GT500s had power steering), belts, hoses, alternator and engine gauge harnesses, and the engine cooling fan/clutch assembly. I haven't added them, because I still have to crank, run and perform the camshaft /lifter break-in. It is balanced with a flexplate and flywheel one is included - your choice. The engine includes a starter, exhaust donut gaskets and motor mounts too. I turn over my engines to the new owner COMPLETE, having already run and with the camshaft/lifter break-in already done. Install, connect, crank, run and drive - yes it is a driver-quality engine.
Here are some of the parts, and their costs:
Engine Block......................C6MEA, Date Code 7B17
Heads...............................C7AE-A, Date Code 7E15 (Both)...................$1700.00 - rebuilt with viton seals, and CJ Valves
Harmonic Balancer.............C6AE-6316-A.............................................$875.00
Crankshaft Pulley...............C1AE-6312-A.............................................$275.00
Intake Manifold.................C7ZX-9425-A.............................................$1500.00
Carburetors......................C3AE-9510-BJ/BK.......................................$1550.00/pr. Holley Re-Issue
Distributor........................C5AE-12127-E...........................................$650.00
Fuel Pump........................4194S.......................................................$275.00
Exhaust Manifolds.............C7OE-9431-A/C7OE-9430-C.........................$450.00
This is a freshly rebuilt engine; I built it with the idea/intent of a 1967 Shelby GT500 Restoration, a 1967 Shelby GT500 Clone or an Eleanor Build. I have built 5 428CJ Engines in the past 2-years. While searching/shopping for 428CJ Components I happened upon the C7AE-A heads and set my sights on searching for a 1967 428PI Block for the 50th Anniversary of the Shelby GT500. This engine is the results of a 1-1/2 year parts search that began late in 2016.
This was very expensive to build - Parts and machine work for the block was actually more than $4000.00. The price for the heads above include acquiring the heads, the parts and labor to get them reconditioned.
Tyrone (334)477-4146
cyberjunk@roadrunner.com
$17,500 firm.
(Once again, I uploaded both pictures so you can see this is a picture of the actual engine that you will receive)
