attaching the front grille molding strips on 1968 Shelby
Started by JWH, March 10, 2019, 10:31:16 PM
JWH
Moving to the front of our GT350 and the front molding -- I have found a set of clips to attach the front grille molding from Branda:
http://www.cobranda.com/grmoatclset.html
What hardware was used by the factory to attach these clips?
Jeff
There is a metal sleeve the branda clip pushes into. The original clips were different dimensions and green in color
68blk500c
68blk500c
By the way, those trim clips from Branda.......originals did not have the white cushion donuts, if you want a correct installation look.
JWH
I do recall the barrel clips now from a car I worked on long ago, thanks the replies.
Jeff
