Does anyone repair 67 deluxe door panels
Started by GT350DAVE, March 29, 2019, 12:32:52 PM
Quote from: DGSOH on March 31, 2019, 04:20:15 PM
Quote from: shelbydoug on March 31, 2019, 11:54:13 AM
I need to re-read this entire thread and re-consider what all are saying? Is there really more then one manufacturer or is that being confused with various VENDORS? Like exactly how many deluxe 67 Mustang door panels are needed?
Tooling is always 95% of a products cost. A dozen manufacturers are going to tool up to sell 500 sets? Doesn't make sense?
From my experience with TMI, Mustang Exchange and Dashes Direct each appears to be manufactured with differing materials and techniques yielding quite different results both in quality and faithfulness to the originals (which none of them are in my opinion). So I'd say there are at least 3 manufactures distributed by some larger number of vendors.
I'm using the Dashes Direct interpretation. Be prepared if you go the repro route, it's not the "splap'em on in there" kind of experience one would hope for.
I've attached an image of today's skirmish - mostly done I think aside from removing the protective film from the aluminum panel, access plug and door pull cup. It'll have to do until I can talk myself into getting the originals redone.
It looks very nice to me from here. My original panels do have the screws in them at the point of the panel. If that's all it needs, just do it. If it was done by the factory, then it is Concours acceptable.
DGSOH
Quote from: Bob Gaines on March 31, 2019, 05:07:56 PM
FYI Ford started to put a screw in the panel at the door opening end as needed . It seemed to coincide with shortly after 67 production started. You might see the screw hole in the metal. This was to hold the panel in better. This is especially helpful with the typical ill fitting repros.
Thanks Bob.
I had this conversation with some others and the consensus was because mine is an early car, 0066, that no screw would be appropriate. Is this not the case?
For the record the panels that came on the car when I acquired it have the screws but who knows if they came that way from the factory... though they are date code appropriate.
The screw is why I want to redo mine.   :P
Quote from: 2112 on March 31, 2019, 06:28:29 PM
Do you mean tha you do want the screw or you don't?
Quote from: shelbydoug on March 31, 2019, 06:37:00 PM
Don't. Otherwise I would just put one in.   ;D
Quote from: DGSOH on March 31, 2019, 05:39:22 PM
Thanks Bob.
I think it would be correct ether way . That is just the way my perception has evolved over the years. Others may think differently. I have seen them on earlier produced cars then #066 that gave every indication were undisturbed interiors. There is no real way to tell if a screw was installed after the fact unless it is too large a hole wrong type screw etc. Even then it is problematic to determine.  I would not replace door panels because they have them nor would I automatically put some in if they don't . I would do as the factory did and only use them as needed. If replacing your panels and you can get them to fit proper then leave them off no harm no foul . It is not like anyone is going to go prying up panels to see if there is a empty screw hole. The few that might feel compelled to try on someone else's car out of some misguided self righteousness will not live long . ;)  ;D
DGSOH
Quote from: Bob Gaines on March 31, 2019, 06:55:27 PM
Exactly what I intended to do.
GT350DAVE
There is a Service Bulletin for adding the screws as a method of keeping the door panels in place.
Support the SAAC Registry
[/quote] It is not like anyone is going to go prying up panels to see if there is a empty screw hole. The few that might feel compelled to try on someone else's car out of some misguided self righteousness will not live long . ;)  ;D
[/quote]
;D  8)
Quote from: GT350DAVE on March 31, 2019, 07:03:57 PM
See attached... Ford titled this a "Retaining Screw Location - '67 Mustang Deluxe Door Trim Panel Rattle"
(note this was a Ford issue notice, not Shelby)
DGSOH
Do we know on what date the service bulletin started to be distributed?
Quote from: tgilliam on March 29, 2019, 08:25:36 PM
Dave,
Gene Painter repairs your original door panels. If the backing board is still good and only the vinyl torn they come out really nice. He has been doing these style door panels for years. There was a period of time that people thought he was "out-of-business" but I have talked with him and had panels repaired in the last two year.
Tom Gilliam
(270) 755 -6417
Thanks. I dealt with Gene on a few occasions on 69 deluxe door panels decades ago and I loved his work. I'm glad to see he is still in business. Gary
I have a Nov 66 shelby. It has the screws at the rear. It was a TSB that would have been applicable to any vehicle returning for door panel loosening, so the date of the TSB Isn't relevant.  I can also tell you that if you do this, FOLLOW THE DIMENSIONS exactly, otherwise you'll miss the metal structure of the door.
As for the door panels, there are several different manufacturers. At least three that are all different. TMI, Dash Designs and Mustang Market are all different. I have seen them all before settling on the dash design door panels. The area the cups fit in were the biggest issue. TMI cut the vinyl incorrectly at the cup openings, Mustang Market panels are actually a bit short and the door handle cup would not fit.
It gets expensive returning them as well.
        -Keith
Bossbill
#43
Dave,
Gene is at (270) 755 -6417
Tom Gilliam
I word-smithed the quote from Tom  so I don't call that number and ask for Tom.
I wonder if Gene can also make the boards flat again? Besides needing a recover, mine are a bit curved I wonder if that rules me out. Might have to call him!
70 B302   6/6/70  0T02G160xxx
67 GT350
Plain and simple, where to go for the BEST reproduction door panel OR complete door panel for a 1967 Shelby?? Lets try not to get off track, I simply want to order a pair of panels and put them on my car where I will be happy.
RARE  Signature Delete
