Rear quarter Window Interior Trim
Started by Steve McDonald Formally known as Mcdonas, March 31, 2019, 07:18:18 AM
Chad
You cannot use these molds to make fiberglass parts.  Also you can not make fiberglass parts fit.  They have to be made out of plastic so you can manipulate them to fit.  The price is probably going to be around $500 per set.
Jbarela
Quote from: Chad on April 29, 2021, 08:02:03 PM
It could be my old age but I just dont understand, is anything being done to strengthen them/reinforce  them so they dont warp just like all our originals did and are?. Just like if an original 65 plastic gauge pod was replicated with the same material, it would just warp again. So excited and 8nterested in this project, I just want to better understand what I will be getting and if it's worth the time and effort for replacement. Thanks again for your efforts.
Quote from: Jbarela on April 30, 2021, 12:14:09 AM
It was not a forgone conclusion that every trim piece or dash pod would warp . Many did but some didn't. To each their own but I think a exact looking quarter window trim would be a God send regardless of if made out of original materials that had a tendency to warp over time or the modern equivalent material that might not as much. At least compared to the ill fitting and different texture looking fiberglass trim alternatives IMO.
+1, would rather have original type then fiberglass
Chad
Guys one thing you have to remember is they parts warped because the cars sat out in the sun as daily drivers for years.  They amount of time your cars sit in the sun now is an absolute fraction of time!
davez
I would also be willing to bet that even if the same type of material is used,  the chemical makeup is different and will behave differently.
Jbarela
I agree 100%, anything that is better than what's currently available is always a winner! Bob made a good point, old plastic versus possibly better modern equivalent plastic. Did not mean to come across as a negative nancy they were just questions of concern. Thank you again
s_eagle
Chad
Hate to bother you but these trim pieces are basically the last thing I need to finish a restoration!  Any updates?  Thanks much
Rob
poboy427
I need a set too to finish my car. The only area of the car I'm still not happy with.
Where to cut templates for the new interior receiving panels would be nice in a kit.
Ray
6S554 Family owed since May 15,1974. Confirmed original alum T-10 4spd, MICO, Steel Pigeon mfg hood
SPF 0373 Cobra S/C, Shelby alum 488 stroker FE Tunnel Port, TKO
shlby66
  For those of you, who haven't had the pleasure, of installing the 1/4 window trim pieces, please be Aware....
  Pay close attention, to the interior sail panels, where the chrome trim, has been cut out for the 1/4 window install.
  Sometimes, the SA workers were not too careful and removed too much material and the opening is too large, to
  allow, the trim pieces, to fit properly. I noticed that the trim pieces ( originals ) in my Shelby never matched at the ends.
  They were spread apart.
  When I went to install replacement trim panels, I found when I had them snugly in the rear, I had about 3/16" gap at
  the front and when I moved them forward, I had the same size gap at the rear. Trying to equally place them in the
  opening, didn't work, as they just didn't look right.
  So my solution, was to procure a real nice set of used interior sail panels and take the time to mark the cut out area
  accurately and was very careful, in cutting out the trim pieces. This paid off, as the replacement 1/4 trim pieces, fit
  perfectly.
  I'm sure, my Shelby, isn't the only one that came from SA, with this condition, concerning the 1/4 windows.  Just be
  aware, it's a possibility and take a close look at what you have.  Good Luck
  Doug Cresanta
s_eagle
Chad
How is your project going?  Looking forward to seeing how and turns out and hopefully getting a set.  Thanks
Rob
kingchief
SFM 6S406
Chad
Good question. We think we have a company that will do the molding but we have to make a few tweaks  to the mold and the vacuum system.  Hopefully I will have some samples in a month or two.  I know I have said that before but I am going on what my friend tells me.  He is working hard on this.
poboy427
+1
The last pieces I need to complete my car.  Mine car will come home without any and will sit this winter til the issue is resolved.
I did not realize Chad was this far in fixing this issue when I mentioned 3D printing as a solution in another thread.
Ray
Chad
Ray I am in the same boat as you.  My Hertz car has undergone a complete resto and all I need to complete it is the trim pieces.  I am supposed to have new samples this month but I am not holding my breath.  You can not push anyone in the plastics business these days.  They have more work than they can handle and a small project like this is of no interest to those companies.
