Original Axle Limiting Cables
Started by texas swede, February 10, 2018, 06:20:55 PM
mygt350
How long is the cable supposed to be?
Quote from: mygt350 on February 27, 2018, 10:12:17 PM
The one in the image below measures 31.25 inches.
march66
These last photos shows a single crimp and what looks like a copper ferrule.  Another interesting find and contrary to what is generally found.
Gary C. Bergman
  Try making a set of tubular "extensions" for the handles for more mechanical advantage.
NC TRACKRAT
Quote from: gt350hr on February 28, 2018, 11:18:53 AM
That would really help except for the fact that the handles have to open up so wide to receive the ferrule that the ends of the tool handles are inside the wheel well...making no room for handle extensions.  After closing the handles about 1/3 of the way (requiring considerable force), I guess you could then carefully slip on some extensions.
5S071, 6S1467
SFM5S000
#50
Stan,
It's not really necessary to have extensions to the crimper. I personally have used the one sold at Home Depot. It has a cam in the pivot that changes the geometry and crushing ability for the user to exert "normal" strength. I used a paper clip to hold the cable in position and let the ferrel rest on top of the clip, then crimped the ferrel. Piece of cake...
Then I returned the crimper back to HomeDepot as I didn't want to own the tool. (Don't tell Home Depot that).
Cheers,
~Earl J
dockbay
Hi Everyone,
Can someone tell me the correct cable diameter?  I see someone mention 1/8" cable. Is that correct?
Cheers,
John
5S276
BTW,, Bo, my bolts traction bar bolts are not shaved even though your car is only one away from mine... I still have what I believe to be the the original NAT bolts.
NC TRACKRAT
Yep, plain 1/8-inch diameter cable, no clear sheath.
5S071, 6S1467
GT350Lad
Yeah thanks I am missing one also
Cheers
6S373
6S1276
