Turn signal
Started by Cam shaft, May 04, 2019, 09:21:49 AM
Cam shaft
We are getting down to the last few details on the little project, and I apologize if we are dominating the forum.
Should the area around and adjacent the front turn signals be body color?
Quote from: Cam shaft on May 04, 2019, 09:21:49 AM
If you are referring to inside the front valance then they were partially blacked out . The black out pattern basically matches the edge of where the black stops on the top edge of the bezel if you projected a imaginary line from the bezel to the sides of the fiberglass valance.
Few pictures to help illustrate
Cam shaft
Thanks to both of you
Cam
