1966 K code parts
Started by usapony, May 06, 2019, 03:51:09 AM
usapony
Looking for a 9" diff centre case to suit a 1966 K code its built September of 1965 so after dates from June - September , Thank you
OldMil
Are you looking for the 9" third member (chunk), or the axle housing itself?  I'm guessing the third member...
Quote from: OldMil on May 08, 2019, 08:26:31 AM
Quote from: usapony on May 06, 2019, 03:51:09 AM
To help with clarification- Center case in OP's post and "Chunk" describe the same thing . Since the rear end housing is not date coded and the center section is then that would also narrow down the item.
