Tower style hose clamps used on pollution systems
Started by Mike Shally, May 10, 2019, 01:21:53 PM
Mike Shally
Wittek made 2 types of clamps, band style clamps and tower style clamps.
Typically you see the band clamps on the pollution hoses however I've seem several examples where tower clamps were used. I have photos of 2 cars built in Nov 67 with these clamps. Not sure why or how long they were used.
original owner, 68 Shelby judge, MCA Gold Card Judge, MCACN Shelby Judge
What applications (big block or small block) are you describing ?
acman63
Mike:  ive seen Tower clamp used on the back of the 68 -70 smog pumps
SAAC Concours Chairman
Having had time to look through the pictures and double check believe you will find the tower clamp usage was typically limited to the hose that connected the back of the pump to the bottom nipple of the check valve
Quote from: J_Speegle on May 10, 2019, 03:53:37 PM
+1
KR500
Quote from: Bob Gaines on May 10, 2019, 05:31:11 PM
+1
+2
Rodney
Mike Shally
Quote from: Shally on May 10, 2019, 08:06:46 PM
Both cars were 302 J code engines
Believe the earlier response applies to J & C codes also that year
I think Mike is saying on the hoses ( in addition to the pump hose)
Quote from: Coralsnake on May 11, 2019, 06:43:02 AM
If he has seen tower clamps on the delivery hoses to the heads on small blocks I've not seen that ever that I can recall on an unrestored car that wasn't played with and believe the engines had all the emission parts installed at the engine plant not the car plant.
Mike if you have seen this what are the assembly dates of the engines or at least the cars? Just for discussion
Mike Shally
Car 006, buck tag Nov27, Marty build date Nov14, serial No.....5308, Engine tag 7-H
the other car 088, buck tag Nov21, Marty build date ?, serial No ....5330, engine tag?
Date on pollution canister 9-7-67.
Both cars built very close together. Photos of car 088 with tower hose clamps in My Gallery will try to move to this post.
Mike Shally
Here are photos of car 088 with tower hose clamps.
You beat me to it, great conversation Mike!
I love the odd balls
Witness lines on the hoses could tell the tale
Just to continue the discussion in a friendly and sharing manner ;)
Quote from: Coralsnake on May 11, 2019, 04:42:16 PM
What witness lines? :)   Of course the example posted will have witness lines.
Mike, have pictures of the same example. Owner was not around when I took the pictures to ask where the clamps had come from. Did you get a chance to ask?
Looked at my pictures and found cars with the wittek styles on cars from
Sept 67
Nov 67
Dec 67
Feb 68
May 68
Of course now will be on the look out for more examples
Mike Shally
This hose used one of each style clamp and I have included a close up of the tower clamp impression. I hope this opens the door a little on the possibility that tower clamps were used on assembly line cars occasionally.  I can't answer why this happened and don't believe either car were "worked on" after delivery.
My issue will be how to present the car and will the judging community accept the variations?
