1966 Starter Solenoid
Started by Karguy, May 12, 2019, 06:18:52 PM
Quote from: GT350Lad on May 13, 2019, 08:30:39 AM
Quote from: Bob Gaines on May 12, 2019, 11:54:53 PM
I have taken apart a lot of these solenoids and there is typically a paper type gasket between the bottom cover and the body . More a labor of love given it takes a considerable amount of time effort and material to refurbish one.
Thanks Bob, I thought they where near impossible to rebuild. I'll keep my eye out for one
Cheers
Some are too far gone but many aren't . I have to use donor solenoid for most parts.
Harris Speedster
Bob,
I am looking at 3 brown / grained solenoids right now.
They all have the large RBM letters
They all have fomoco in the oval circle.
But;
They have this part number  FDR-11450-A
This part number is located where the part numbers are on the solenoids shown herein.
They are otherwise identical.
What gives?
John
Quote from: Harris Speedster on May 13, 2019, 02:20:38 PM
Bob,
But;
What gives?
John
Look at the front and see if it has two small terminal posts as typical or just one.
Harris Speedster
Bob,
All three have the dual small posts up front.
There is a 4th one that has a single post, same lettering and numbers,
BUT, it has the fomoco in a rectangular box, rather than the oval circle.
Quote from: Harris Speedster on May 13, 2019, 03:27:56 PM
Bob,
I thought it might be one of the different application styles with the single post not like Mustang.I suspect a early variant. Sorry ,I can't be of any help .
Sounds like a service replacement for the 52-55 6 volt applications maybe for even slightly earlier, given the markings as you describe.  Even earlier version has a button on the bottom that you could use to manually active the solenoid rather than jumping the posts. Really handy. Have one on my 40 Ford
One of the applications for the ones marked "FDR-11450-A" with the dual small posts is mid 50's Fords
Harris Speedster
Quote from: J_Speegle on May 13, 2019, 04:59:43 PM
Jeff,
I would venture to say that your assumption is correct, mid 50's, and I would guess, up to early 60's.
Coopers parts range for decades.
Thanks guys, at least i know what they are meant for.
Look 100% spot on, but have the numbers and Fomoco circled as noted herein
