Seam Sealer on Drip Rail
Started by motorhead428, May 15, 2019, 09:47:51 PM
motorhead428
We are getting real close to painting our 67 GT500.  I was reviewing Jeff Speegle's  Restoration Support document and noticed that the drip rails above the door window's need Seam Sealer. Because the body was blasted which removed the sealer, I don't know what size bead would be appropriate. His document does says to use self leveling but I could use a picture or two as a guide. Any help or suggestions would be appreciated. Thank You Rick
johnsshelby
I am thinking same as you. I don't know the proper sealer to use, my car is painted without sealer in the drip rails.
Quote from: cbrown on May 30, 2019, 11:14:48 AM
3m 5887
+1  Not sure if its the same thing but many have used 3M Firm and Fast for years. They are always changing names and numbers it seems
cascade-classics
Are you sure about that number?   According to the 3M Website 5887 is "a flexible two part epoxy material designed for use in the repair of flexible and semi-rigid plastic parts".
Might want to check with the place you're buying primer/paint for the car and ask their opinion.  Would hate to lay on a pretty paint job and the paint curls where the sealer was applied.  The original stuff was a dense pinkish/whitish material, believe the same used on the cowl lip/edge.
Product I was referring to is
3M Fast 'N Firm Seam Sealer 08505
Do agree that it's always good to check with your painter and reflect on what products it will be going over and under and if all of them are compatible
cbrown
I use 5887. It is really easy to use and is self leveling so it lays out really smooth
Yes it is a flexible bumper repair but works good for me. You don't have to go back over and smooth out.
