Tail light pigtail
Started by jswoody, May 17, 2019, 04:57:05 PM
jswoody
Probably impossible, but I am looking for a single pigtail for a 1967 GT500.
JWH
Is this what you are looking for?
http://www.virginiaclassicmustang.com/67-SHELBY-TAIL-LIGHT-WIRING-EXTENSION-PLUG-SET-BOTH-SIDES-P2362.aspx
Brant at Virginia Mustang has the sockets for the light bulbs also if needed?
Jeff
Quote from: JWH on May 17, 2019, 10:22:20 PM
Jeff
That is the later style 67 Shelby tail light pigtail. It is OK if you don't have anything else but besides that style only being used in later production it is easy to tell as a repro from examples I have seen.
Krelboyne
Might be the same as 1967-68 Cougar? 6 different identified by specific stripe on wires. An example
Quote from: Krelboyne on May 20, 2019, 11:49:08 AM
Shelby typically used only the Green and Black wire bulb receptacle on both sides unlike Cougar which used one color on right and another on left. The special identification didn't matter in the case of 67 Shelby being that they were being attached after the fact to the Mustang tail light harness. Interestingly the green and black wire (different gauge wire) was also used for the center headlight harness and horn wire extensions for the outboard light cars.
