69 GT350 A/C hose question
Started by SChatman, May 19, 2019, 12:37:02 AM
SChatman
Any thoughts on the correct hoses for my A/C? I've included a picture of the high pressure hose that was on my car when I got it 25 years ago. Now I'm looking for replacement hoses for my restoration and I've checked the Classic A/C website, they show a straight hose with no bend for the 351W and the hose with the bend fits a mustang with a 390 or 428. I'm also including a picture of the straight hose that Classic says is correct for my car and the one they say is for a big block.
Thanks for any help.
The one without the tube extension is closest of the two you posted for a replacement IMHO
Originally there was no long tube just the four sided sight glass and the fitting. The tube from the dryer is pretty long and reaches well into the engine compartment as you can see below
Some examples
SChatman
Thanks Jeff but it looks like the end that has the bent tube attaches at the firewall, do you have any pictures of that end? The end of both hoses (big block and small block) with the sight glass looks about the same.
The reproduction hoses will function like original but will NOT look original. They will look new and fresh to a untrained eye however. The best bet is try and find some nice used 69 A/C hoses if you want original look. I take nice originals and replate the ends for a new appearance.
Sorry - up too late responding
So looking at the firewall end of the small line in the MPC doesn;t appear to help since they do the one size fits all it appears in the later 72 version I have handy
Not the easiest location to get a picture of plus the lines are often sill covered with the insulation if they are still attached
Could only find examples from San Jose cars and early cars at that so it does leave open the possibility that the line design changed during the production year. Have seen that line with a short straight attaching hose also and looking at 70's small blocks they appear to have the same. So juts leavign that possibility out there
SChatman
Thanks Bob, good suggestion. What's the plating on those fittings?
Thanks to you as well Jeff, mine was a Dearborn car and all of the pictures you show have that tube with the bend in it just like mine which Classic lists for a big block. If I decide to get the reproductions I'm going to stick to that same style with the bent tube.
Quote from: SChatman on May 19, 2019, 08:38:44 PM
The steel fittings you can do in zinc silver and look right. FYI the original hoses are the same regardless of BB or SB.
