68 GT 500 # 147
Started by OldMil, February 13, 2018, 02:41:05 PM
OldMil
Does anyone have any information on #147?
Mongo
#00147 GT500 fastback White, black interior, 4-speed, no tilt, non a/c & hub caps from the factory
OldMil
Thanks for the quick response.  So how is it known that there was no tilt?
Quote from: OldMil on February 13, 2018, 03:07:39 PM
Because Mongo has all of the factory records . Mongo = keeper of the flame 68-70.
OldMil
So on an early car (late Nov, 67) that would make sense.  The car also has the "Extra Cooling Package" which should be the 24" radiator, fan shroud, clutch fan from what I can research.  Anything missing from that list?  How about a Power steering cooler?
Quote from: OldMil on February 13, 2018, 03:43:53 PM
Extra Cooling Package was typical through production on 68 Shelby.
Mongo
#00147 was built with the same dso as 10 Shelbys and the other 9 built at the same time do not have tilt. Also the invoice for those cars do not show tilt $ being charge for.
OldMil
Thanks for clarifying.  If anyone knows any history on this car, please weigh in.
All 68 Shelbys should have the small power steering oil cooler, as installed by Ford
None of the 68 Shelbys had tilt at the start of production
Earliest known Ford build date for tilt in 68 Shelby is 12/1/67
KR Convertible
#11
147 was probably built 11/25/67, same day as mine (181).  If I remember correctly, big if, there was around 100 GT500s built that day at Ford.
KR Convertible
I'll dig out my registry in a little while and check.
KR Convertible
Is this a car you own? Are considering buying?  I would love to know some casting dates.
