65 Instrument Cluster Lamp Socket
Started by mygt350, June 05, 2019, 08:11:56 PM
mygt350
Have a 65 Mustang instrument cluster and am having hard time keeping the oil and alternator lamp socket in the cluster. Socket will stay in place until you move the cluster, then it falls out. What do you do to keep the socket inserted in the cluster? Replace socket with something that fits tight, glue it in or something really drastic?
Martin
does it have little prongs on it? If so they can gently be bent outward.
mygt350
Its the plastic socket with two wires. It has segmented areas that used to create holding friction but over time, the metal to plastic has eroded the socket and it will not stay in place. Think its .625 diameter. The metal sockets have the tabs and they are holding strong. The plastic socke4ts are the problem.
mygt350
Nope, just press fit. Here is a picture of the rascal.
