Fender bolt
Started by TedS, June 13, 2019, 07:58:50 PM
TedS
Yea, I know, the fender bolts are not supposed to be painted body color. That's what I intend to fix. I'd like to buy a set of correct replacements so I can take these out and strip off the paint at my leisure. However, I haven't been able to find any that match these markings. I assume they are original.
Ted
AMK makes a reproduction, but it's not 100% exact.
Restoring the originals would be the best way to go.
TedS
Thanks Charles
What's the finish supposed to be? I've seem phosphate and natural.
Ted
That is a late 1968 head marking. They were original a silver zinc finish (shinny not satin)
TedS
Thanks Pete. That fits with mid-June '68 build date.
Chris Thauberger
How many are you looking for?  I have quite a few fasteners leftover.
Chris
Previously owned:
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
TedS
My car is in remote storage so I was wanting a full set of 12. That way I could change out all 12 in one trip but still have correct bolts while refinishing the existing ones.
I can get the AMK set that Charles pointed me to but I would have to find some other fasteners to buy to meet AMK's minimum order.
I know, I'm making this too complicated. With the car in remote storage and all the things I have going on in life I have to think in terms of small tasks I can start and finish so I can still drive and show the car every chance I get
Thanks to all
Ted
Corey Bowcutt
Ted,
You can very often get the same AMK fasteners sold by many of the common Mustang supply stores without the minimum order situation.
Corey
TXShelbyman
Would these headstamps also be considered correct for January - Febuary Shelbys?
When things go bad just hit the throttle, may not solve the situation but does end the suspense.
Formally watts428
I would say the r-b-w bolts with the target were used...
..the anchors were typically used by AOSmith and are usually black phosphated. They hold hoods and decklids on the hinges
The other common bolt looks like the one above, but an "s" replaces the four dots (first post)
Every Ford bolt has a unique number. This bolt is numbered 378178. You can identify which bolt you need by looking at the Ford assembly line manuals. This bolt is commonly used to mount front fenders.
A part number suffix is added to identify the finish on the bolt. The bolt on the left is 378178-S7 . The "S7" identifies the silver finish. This bolt tends to be on later built cars. The bolt in the center has the same part number, but a different head design. This design is more common on early built 1968 Shelbys.
The last bolt is a 378178-S2 . AO Smith used the black oxide version of this bolt to mount hoods and rear decklids to the hinges on 1968 Shelbys. It has a small anchor as a design.
Chris Thauberger
#10
Quote from: TedS on June 14, 2019, 11:03:19 AM
Thanks to all
Ted
These work for you?
PM me you address, no charge.
Chris
Previously owned:
1973 Cougar
1968 Mustang coupe
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
TedS
Wow Chris, that is so nice of you. PM on its way.
And thanks to everyone for the help and information provided.
Ted
Mike Shally
Car 006 built Nov 67 had SI style bolts on the fenders.
Yes this is the second time I have gone thru a ground up restoration but I can tell which bolts were re-plated.
There were also several 67 style bolts used on the hood and hood spring area. These bolts had the star style washer.
original owner, 68 Shelby judge, MCA Gold Card Judge, MCACN Shelby Judge
TedS
#13
Quote from: TedS on June 14, 2019, 06:40:07 PM
Ted
Just to follow-up...
Received a set of bolts, courtesy of Chris T, and what a difference 12 new bolts makes. A pack of new bolts and 30 minutes of time to change them out and something mediocre now looks professional. Before and after pics below
Ted
Chris Thauberger
Much more authentic than the painted ones Ted.
Have to love it when a plan comes together.
Lookin' good.
Chris
Previously owned:
1973 Cougar
1968 Mustang coupe
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
