tire selection for steel wheels
Started by acman63, June 14, 2019, 06:02:18 PM
acman63
who has run modern radials  with the 15 x 6  steel wheels.   brand ? , size ?,    no clearance issues tire?
SAAC Concours Chairman
zray
Quote from: acman63 on June 14, 2019, 06:02:18 PM
I put a set of Avon CR6ZZ tires (215/60-15) on a set of Ford 15x6 wheels with 3 7/8" BS'ing. The car was a '65 K code. I can think of no other suspension improvement for the money that will transform a car so dramatically for the better. Absolutely no rubbing issues,
http://www.avonmotorsport.com/historic/historic/cr6zz
I'm pretty certain a set of 65 profile tires would've fit just fine too. Certainly they would on the '67's.
Z.
PS  single wheel pictured was not the one I used, but has the same backspacing, etc.  mine were likely from a '70's econoline van.
Bossbill
Since those wheels have no nubs for hubcaps it's doubtful if they are from an Econoline. Most vans had dog dish or poverty hubcaps.
From what I've seen while looking for wheels, those are likely from a Crown Vic.
I like the look of the no nub wheels.
70 B302   6/6/70  0T02G160xxx
shlby66
      +1 on the AVON CR6ZZ's. Great vintage look and loads of performance. No disappointment there.
      I used,  AVON 215/70-15's  on Shelby Cragars and they look killer. No rubbing issues.
      Doug
zray
Quote from: Bossbill on June 14, 2019, 11:42:03 PM
Thanks for the clarification, IIRC, my wheels had a 1970's date code.  No longer have the car so I can't be certain.
Quote from: shlby66 on June 15, 2019, 02:23:09 PM
      Doug
I've heard from a few people that the 215's were too wide for a 6 inch wheel.  However, my experience seems to fly in the face of that assertion.  The contact patch, traction, and tire wear were all excellent, and identical to the 215 Avons I've had on 7 inch wheels.
Z
