2 Original Shelby Export Braces
Started by nate, June 16, 2019, 10:09:45 AM
nate
2 Shelby Export Braces. Both in good condition. Priced at $160 Each + the ride
Call or Text 1-812-661-7743.
Best,
Nate
nate
aj
I'm interested.  Check your messages.
nate
69mach351w
What makes them Shelby export braces?  I know that any 65-66 Mustang that was exported out of the country got the export brace.  Are these specific to the 65-66 Shelby only with some sort of mark?
Quote from: 69mach351w on June 24, 2019, 08:51:28 PM
Those were meant to fit 67 /68 Shelby's because of the bolt pattern.  The ones used on the 65/66 GT350 had a different evenly spaced bolt pattern. The uneven bolt pattern like pictured would also fit other model years besides 67/68 Shelby's .
69mach351w
Bob, Thanks for the Clarification 👍🏻
Quote from: Bob Gaines on June 25, 2019, 01:02:35 AM
I had a 67 T5 Fastback that came from the Factory with an Export Brace, would it be the same as the one on Shelby's?  If so, was it Ford or SAI that installed the one's on the Shelby's?
