WTB - 65 Mustang Turn Signal Cancel Cam
Started by mygt350, June 18, 2019, 06:32:43 PM
mygt350
Car has a Grant steering wheel installed and horn is failing. Grant uses couple roll pins to cancel turn signal. Original cancel cam was removed and is gone. Have a repop wheel boss for 6-bolt wheel that is identical to the 65 GT350 adapter. I need the Ford turn signal cancel cam that attaches to the adapter. Anyone have one?
Believe its part number C5ZZ-13318
mygt350
Doug C
Is a 66 canceling cam the same as 65?  If so I can use one as well.  Thanks
