1967 GT350 B/FX racer found in Chicago.
Started by Thomas, June 19, 2019, 11:07:45 AM
Bobby Crumpley
Randy, no doubt that you and Jeff are correct about what the car needed to stop, but we have all seen plenty of cars that people just kept adding stuff to so that it looked the part.  In the late '70s, we had a guy in town with a chute on the back of his Camaro street car, and I can assure you that it had no need for one.  It sure did intimidate people though...
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com
Thomas
#166
Morning everyone.
I have lots of part number pictures and updates to post but cannot post them due to the uploading issue on the forum. I will post them ASAP when the problem is resolved.
However, I'll list the numbers that I found for now.
Drivers rear spring: C7ZA
                             5_ _ 6AM
                             040EC7
Pass rear spring:  C7ZA
                           _ _ _ _AM
                           04_ _ _ _
Rear axle had an Oval flange center: 28-spline
Driver door upper hinge: 32123LH
                                     SPO or SPC
Pass door upper hinge: 32122RH
                                   SPC
                                   8
Passenger door striker: 1-67
capecodmustang.com
Thomas :
Has the steering box been changed?
Thomas
Quote from: capecodmustang.com on July 11, 2019, 10:08:38 AM
Thomas :
Yes. It has a Chevy Corvair steering box. I'm assuming that its what the drag racers used when they converted to the straight front axle.
Bossbill
#169
Quote from: Thomas on July 10, 2019, 12:46:33 PM
Bossbill;
I will try to get the car out today and take better pictures of the radiator for you. Thank you for your help thus far.
Are you able to make any distinction as to a window of when this radiator would have been assembled into the car?
See pic for where to take the pic.
70 B302   6/6/70  0T02G160xxx
Harris Speedster
Have you looked at the date codes on the side door window glass?
Seems to me that with whats known at this time, April  car?
Thomas
Quote from: Bossbill on July 11, 2019, 07:37:11 PM
Bossbill;
Here are the Radiator pics from yesterday.
Thomas
#172
Quote from: Harris Speedster on July 11, 2019, 08:40:52 PM
I wish that I could. The car has all lexan windows. As far as the build date, I'm building a chart to track stamping date codes for the car. My hope is that somehow I'll be able to figure out what the timeframe is from the part manufacturing process date  to vehicle assembly date. This would give me another possible window to investigate. Might be able to align it to a certain DSO group, then break it down by color etc...
As a few of the members have recommended, I'm following every bread crumb that I can.
Thomas
Those are AM marked competition suspension springs which are consistent with earlier production 67 Shelby's .
Thomas
#175
Here is the axle, the door hinges and the door catch.
Thomas
This is a better orientation on the Radiator pic .
Thomas
#177
I have another question for the group. I believe that the lower rear lower valance looks to have been replaced due to the Phillips screws that are used to fasten it onto the car. The strange thing is that its welded in the corners and it has the same paint and patina as the rest of the car? Anyone have any info on if these were modified or replaced for some reason at the assembly plant? I've attached a couple of pics to show what I'm referring too.
I've also made further progress on getting some more of the black paint off. Unfortunately the blue stripes seem to wipe off fairly easily. They are there, but when I rub the black off, the blue comes off with it.
  Thomas , 28 spline axles are what you have and ( for me) broke the driver's side when the et's dropped into the 11 second range. many racers "back then" did what they could with what they had ( me included) . I switched to 31 spline axles almost 40 years ago .
Stripes were originally vinyl not painted
