cleaning sockets for tail lights
Started by RSOHC, June 20, 2019, 01:19:02 PM
RSOHC
In the photograph by JWH I see one wire.  One end of the wire is connected to a screw that is not used by the factory wiring assembly.  To what location is the other end of the wire attached? I assume one wire is needed for each of the steel tail light housings.
Lauran
Thats not a factory wire and to further complicate matters the housings are white metal which is not a ground
RSOHC
I have run a wire from each steel tail light housing.  One end of the wire is attached to a screw not used by the wiring harness.  the other end is attached to a screw in the steel panel that makes up the rear of the trunk.
The turn signals work front and back.
The emergency flashers work front and back.
The brake lights work.
When the headlights are turned on, the headlights flicker and there is a clicking sound perhaps from the relay in the new ignition switch.    the gauge lights for oil pressure and water temperature flicker.  There are no tail lights.  I have not yet checked for a burnt fuse.
What might be causing this problem?
Lauran
67350#1242
#18
Is the clicking coming from the headlight switch?  There is a thermal overload breaker inside in line with the headlight circuit.   I believe the tail lights are also on the same circuit.  Try unplugging one tail light or headlight at a time to isolate the short.  It is also possible that after improving all your grounds the circuit is now drawing more current and exposing a weak headlight switch breaker.
Kurt.
RSOHC
I have soldered wire between the sockets and to a ground in the trunk.  the clicking of the ignition switch has gone away.  I have no tail lights as before.
By what method does the ground find its way to the tail light panel which is fiberglass?  Is it the black  wire  with an electrical eyelet?  How does power get to the rear light bulbs when only the tail lights are on?  I still have no tail lights when the headlights are on.
Lauran
RSOHC
What flashers do I need for the sequential tail lights to operate properly?
Lauran
Chris Thauberger
#22
Previously owned:
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
RSOHC
What is the number of the green flasher in the dash board area.  I have a Wagner 552. Is this correct?
Lauran
We have no way of telling what number you flasher is?
There are two flashers under the dash, the turn signal flasher and the emergency flasher
TS flasher 323. E flasher 552. On original system e flasher will generally not sequence outer bulbs. This is normal.
RSOHC
At this point I believe the tail light problem has been solved.  I checked the black wire for running lights and the black wire for the ground associated with the dynamite sticks and they were reversed.   I swapped the two wires and all the functions with the tail lights seem to be working just fine.  Thanks for all the help.
Lauran
Quote from: RSOHC on July 07, 2019, 06:17:30 PM
Lauran
Reversing those will usually toast your TS switch. You are lucky if it didn't
RSOHC
Chris Thauberger
Previously owned:
1973 Cougar
1968 Mustang coupe
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
