A/C Clutch
Started by johnzajc@gmail.com, July 18, 2019, 04:27:32 PM
johnzajc@gmail.com
I need field coil for A/C Compressor clutch---C9AA 2981 D2---I do not know correct part number for coil , nor I do not know if they are interchangeable with other clutches---thank you
Mike_Senar
What is that engine application for?   There is something like four different ones!
        Mike
johnzajc@gmail.com
Hi --it is for 428 cobra jet and is ford original compressor--thank you---I almost gave up[[thanks]
John the field coil you need for the D2 clutch is C9AZ 2987 A. The D2 is typically found on 70s more than 69s. Is your compressor a D0AA or C9AA? There is one shown on Rearcounter. Worth a shot even though most items on Rearcounter are still listed even though sold already
https://www.rearcounter.com/C9AZ-2987-A-parts223359.html
johnzajc@gmail.com
THANKS--will take compressor of the car for clean up and check the numbers--it is very posible it was changed during the life og the car
johnzajc@gmail.com
just check the clutch and is  C9AA-2981-D2
is there a compressor tag?
johnzajc@gmail.com
Thank for your time        Painfully we can read tag        Size              2.5 inch. x 2        Inscriptions:        Row 1            69-99 206-1        Row 2            HG 1000 C9 A 1216 A        Tahg is riveted by 2 what appears to be # 3 standard cold rivets  same as we use on aircrafts---        I am determined to leave to my grandchildren some original that represents true era of American masterpiece.
OK c9az a is the one you need. Did guy on rear counter have one?
johnzajc@gmail.com
Thank you-- I am back tomorrow & will check--the one we have NOS C9AA 2981 ca we use in dire need or is totally no-go
