GT-350 Engine & Other Parts
Started by marvs289, July 20, 2019, 02:58:05 PM
marvs289
o (1) C3 Casting, 4A14, Tested, $1000
o RARE '67 TE Heads Set Castings, 6M22, Tested, $1800
o RARE '67 Rebuilt Set Non-TE Heads, 6M8, Tested, $2400
o RARE '67 Rebuilt Set Non-TE Heads, 6M22 7E8, $2200
o Used C8 Set Heads Non-TE 9K23, $1500
o Used Rods, Floated, $500
o Used Rods, NOT Floated, SOLD
o NOS Boss 302 Rods, not numbered, $900
o Used STD Pistons, $350
o New Set Sealed Power 4.030" Pistons, $400
o Used Fans, A67, Like New, $600,  G4, $700
o C5 Distributors, Used $500, Rebuilt $625
o Used Motorcraft Distributors, $350
o NOS Valve Springs (6), $25/each
o NOS Valve Spring Retainers, $250
o Used C5 Damper, A5, $500
o NOS C8 HiPo Damper, $275
o RARE Original C5AF-10A352-C Alternator Pulley, used until 04/01/1965, $175   1 Left
o Original C5AF-10A352-H Alternator Pulley, $125   1 Left
o NOS Early C3 Timing Set, $425
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight, AND Thrust Plate)
o NOS Later C5 Timing Set, $325
(includes NOS Cam Gear, NOS Timing Chain, used Crank Gear, used Counterweight)
o Aluminum Water Pumps, Rebuilt, $400
o VERY RARE Reman '65 Cast Iron Water Pumps, C5OE-B Repro Impeller $425 (used May-August '65 only)
o Reman '66-67 Cast Iron Water Pumps, C6OE-A Repro Impeller $325
o Original '65-66 Firewall Heater Delete Plate, SOLD
o NOS BF-601 Spark Plugs with Stars, box of 10, $100
o Rebuilt Original S2MS Carburetor, 755, $1250
o Used K-H Disc Brake Porportioning Valve, $150
o NOS Early FoMoCo PCV Valve, THREADED, $80
o NOS Rocker Arms with Fulcrums, SOLD
o Used Timing Covers, $125
o NOS Autolite Bypass Hose, $40  only 2 left
o NOS Piston Pins $80
o Used C5AE-A Crank Pulley, $40
o NOS Oil Pump with Pickup, $150
o NOS Gaskets, Head $100
o NOS '65-66 GT-350 WHITE Stripe Kit, one GT-350 decal missing, $150
o NOS '67 GT-350 WHITE Stripe Kit, $200
o NOS 65-66 Parking Lights, Both Sides, $250
o Rebuilt 3734S Fuel Pump, $400 (early Cobra I think)
Pictures upon request. Prices do not include shipping from VA. I will combine shipping in the case of multiple purchases. Pictures upon request. Thank you
paul
Shelby_r_b
Nothing beats a classic!
