289 Cobra/Lightweight Galaxie Aluminum T10L transmission - new /nos
Started by acman63, July 21, 2019, 07:52:10 PM
acman63
Cobra T10L  Aluminum T10 Transmission - New!   289 Cobra/Galaxie Lightweight T10L aluminum transmission  .  Transmission is new and ready to go.  We used  one of our last  concourse aluminum  case and tails  which we had made awhile back and saved it for doing a  complete transmission .  These parts were made using nos originals to make the tooling and were beefed up in areas inside that were always an issue with original transmissions . We have accumulated some very hard to get NOS 2.36 ratio nickel alloy parts to build this.  Includes  all  possible NOS original high nickel parts including nos  26 tooth  - 10 spline main drive , close ratio cluster , 1st gear, 2nd gear, 3rd gear - .   Also includes super rare  NOS Ford original 28 spline main shaft . It took me 5 years to accumulate these rare nos  parts.  The build includes clearancing gears for better oiling in high performance usage , New Premium Severe Duty bearings.  Racing cutback synchros with premium blocking rings.  All new small parts and bushings .  Blueprinting and assembly by the best T10 guy I know . When have you here is basically an all new Transmission? The only used parts in this trans is the mid plate and the side cover both excellent shape.  Original r This type of transmission was used in 289 Cobras and lightweight 1963/4 Galaxie.  we will provide the proper crankshaft pilot bushing depending on application. I doubt you will ever see another trans that was built with all these NOS original  parts. The shifter assembly is an excellent original unit , the control box has been dis-assembled - cleaned - stripped - mil spec cad plated,  re-shimmed , greased with new beehive spring, phosphated pins,  new spring washers and clips.  Rods are phosphate plated with cad plated levers - new spring washers and clips .  No shift handle included!    Transmission will be shipped in a custom wood crate with padding inside . First  $10,995  ,   Free shipping with prepaid paypal friends and family or check or wire transfer in USA.  CC  will pay shipping about   $175 in 50 states  or pickup up in Green Bay ,WI  We also ship worldwide.  any questions contact  Jim  (920) 434 3645 (days)     jim@shelbyparts.com    check us out  www.shelbyparts.com
SAAC Concours Chairman
acman63
