65 Hipo Dual Point Distributor Shaft and Lower Bushings
Started by mygt350, February 17, 2018, 02:50:09 PM
mygt350
I am looking for a 65 Hipo Dual Point distributor shaft. Prefer NOS but would look hard at a really nice used one. Have the points cam, cam gear and collar. Just need the distributor shaft. Also looking for 2 NOS lower distributor bushings. Dizzy is C50F-12127-E FoMoCo
mygt350
Bump.  Part number for the lower dizzy bushing is C5AZ-12132-A. Looking for 2 of them.
Still looking for NOS dizzy shaft for a C50F-12127-E (small block) dual point. Could also use NOS Points cam/reluctor. Part number C5AZ-12210-A. This is the 13L and 18L mechanical advance for a C50F-12127-E (small block) dual point.
FYI these parts are seldom seen NOS. The used versions of the parts are seldom sold separately . It certainly doesn't hurt to ask and course best of luck ,but I wanted to mention this in case you thought the lack of response was because others were ignoring you.
mygt350
Thanks Bob
I may get lucky and something surfaces.
Martin
KR Convertible
I had the same problem with my distributor.  I ended up buying a new Duralast distributor from Advance Auto.  The internal parts are the same dimensions as the original.  I used the shaft in my original housing.  I'm not sure if the dual point shaft is different or not, but worth checking out.
My next step was going to be grinding the shaft true and making oversized bushings.  If the shaft is only worn at the bottom bushing, you can make one oversized bushing for the bottom to improve the slop.  Mine was worn at the top bushing.
mygt350
Bump
Still looking for a NOS or really nice main shaft for a C50F-12127-E (small block) dual point . Have set of NOS points, NOS points cam and other components, just need better shaft than the one I have. Any joy out there?
Thanks for looking.
PM or e-mail. Retired so no matter..
stephen_becker
I had a nice used one that was rebuildable about 6 months ago and sold it for 1500.00
Wish I could help ya
SGB
al8apex
not sure if this request is still valid but ...
Have a NOS C5AZ-12210-A 289 HP rotor cam
This was available from the Don Roberts RACEngineering estate
Edit: spoken for via a FB group, thanks
mygt350
Did 65 gt350 HiPo dizzy have a 10L/13L or 13L/18Lreluctor ?
mtdubvee
I have an entire complete distributor for sale. Dated 4M for HIPO. Message me if interested.
SFM 5S123
SFM 5S269
1967 GT350 #41 Raven Black 4 Speed
Rukiddin
