dash VIN plate
Started by kasearch@ix.netcom.com, August 17, 2019, 02:15:39 PM
When Shelby renumbered the dash plate, what did they do about getting the PROPER rivets?  Does anyone reproduce those rivets now? I want to remove my dash VIN for having the striped down body media blasted and then need the proper rivets to put it back together.
Chris Thauberger
What year are you referring to?
Previously owned:
1973 Cougar
1968 Mustang coupe
1966 Mustang 4 speed vert
1965 Mustang coupe
1968 Cougar
1971 Montego
1968 Torino GT
1966 GT350H clone
TOBKOB
Shelby didn't renumber the dash vin plate... :)
TOB
1969 GT350 owned since 1970
Quote from: TOBKOB on August 17, 2019, 04:23:38 PM
TOB
I believe OP is referring to the added 1970 Shelby dash VIN plate.
TOBKOB
QuoteI believe OP is referring to the added 1970 Shelby dash VIN plate.
Bob, I assumed the OP was asking about a 69 since his other questions have been about a 69 GT500 but we both know what assume spells...  ;D
TOB
You are correct that I do refer to the 69.  Sorry for the confusion, and Yes I am referring to the added VIN plate.  But the real question is, where can I obtain the correct rivets?
TOBKOB
The dash vin plate was installed at Ford but I don't know if you can buy the correct rivets. I remember a few years ago that someone had a limited number available but I think it is a security reason(fraud) that they aren't generally available to the public. Someone with more knowledge can chime in.
TOB
  That is correct.  Back in the sixties there was a lot of car theft issues.  So, the government had the manufacturers make special rivets.  How about trying to cover your current plate before the media blaster has at it.
I will try to cover the plate.  What was special about the rivet?  What do they look like?
  Well, I'm wondering why you are asking.  Has it already been taken off?
    Anyway, it looks like a pop rivet with rounded eight points
I was looking to remove it before it went to media blasting. I can do my best to protect it, but thought it better to remove and replace.
Its called a rosette rivet and it is available
Thanks Coralsnake.  Can you tell me where I can obtain them?
There are several vendors online, just do a search. i would guess AMK products also carries them
I have not seen enough 1969 rivets to know, but the earlier cars just used a regular rivet
Quote from: kasearch@ix.netcom.com on August 17, 2019, 02:15:39 PM
When I had my car stripped I never had them blast that area. I have not seem 69s that had problems in that area. I MADE SURE that the upper cowl and firewall were not done as I have my original sealers still on it-can't get more factory than that. Does your firewall upper windshield area need work? I left the windshield in my car when it was blasted and kept the fact paint and blackout on that area as well as most of the firewall. Gary
