CORRECT 67 GT500 PCV VALVE GROMMET
Started by Mike James, August 24, 2019, 07:51:25 PM
Mike James
Anyone ever blow out a PCV valve grommet?   Possibly mine was old and rotten, not quite sure.
Anyone have a part number for the correct one?
Mike James
I think I might have the wrong grommet.  My grommet has notches but the valve cover on the right side of my car does not have the notches.  Could that cause the grommet to blow out?
Quote from: Mike James on August 24, 2019, 07:51:25 PM
They don't typically blow out . The PCV and hose would also hold it .They twist into a key way and it would be hard for them to blow out at least with the lower ears in place. More like old and rotten ones crumble apart and are lost that way.   Repros are out there. I can't help with part number but originals can be identified by a C7AE -6A892-A engineering number and a FoMoCo in block letters inside a rectangle.
Mike James
Bob,
So are the notched ones correct?  The valve covers don't have notches like the repro ones.
Quote from: Mike James on August 24, 2019, 11:01:58 PM
Bob,
All the ones I have seen had the the rubber bottom ears/notches in place but had the top ear set cut back flush. All of the vintage magazine photos I checked of obvious early production and later production cars (by characteristics) show the wide diameter grommet.  If there was another one that was more typical I would like to know about it.
Mike James
So I need to cut the top notches off the grommet?  Definitely had two sets of notches.
Quote from: Mike James on August 25, 2019, 12:01:20 AM
If you don't that grommet will not work.
The reproduction grommet is a real issue. It's also a much softer rubber than the O/E unit.
        -Keith
