65 GT350R model Parts -updated
Started by acman63, September 01, 2019, 09:55:07 PM
acman63
65 parts  R-Model
Side window kit -  complete  kit - aluminum frames.  -precut plexiglass.  mounting hardware kit,  directions.  $1200
rear window kit . extruded aluminum frames.  center bracket, clear plex moulded  window  $1200
door panels - lightweight aluminum,  with correct push pins  $195  pr.
Rear Seat replacement (shelf) fiberglass.  Quality part with woven trunk area. Precut shock and spare tire mount holes $450-  marked and not cut $395
Early 16 inch steering wheel with hub $650
Radio delete plate $35
Heater motor firewall  delete plate  $35
Rear folding seat latch delete plate  $20
Trunk Mount Battery Tray kit -  includes tray with mounting hardware,  hold down with correct long carriage bolts and nuts.  Long positive cable,  correct dipped cable clamps and proper rivets.  Negative cable   $525
Ray Brown Seat Belts - original restored chrome  hardware , short floor hooks   $1595
Seat Belt Anchor Bolts   $175  set of 4
Fiberglass Bucket Seat with cover  $495
Tri-Y Headers - concours  $995  bare steel -  $1190  Satin metal ceramic coated  .(back ordered - 4-6 months backlog right now
Hood latch delete bracket  - concours  $75
Driveshaft support loop  -concours  $75
Grille Moulding center Bullnose - polished aluminum  $95
Fiberglass Hood  - Concours  lightweight fiberglass  $850
Hood Prop rod  $35
Koni Shocks  new set of 4    $550
Front shock upper mounting brackets with welded washers   $125  pr.
Front shock upper "Koni"  bolts  - special extra length -concours correct  $60 set
Rear Shock stud covers "Koni boots"  Bellshaped - concours  $50 Pr.
Interior 1/4 panel fiberglass trim panels - replaces louvers  $125  pr.
Heater control delete plate $29
Trunk lock delete  - hold down kit  $129
American racing Wheels 15 x 7  $550  set with lugs
Interior 1/4 panel light plugs  $20  pr.
Fender logo - concours  $55  pr.
Oil pressure braided line  $95
Oil pressure Block fitting  $40
Front racing apron $235   Concours $275
Cobra logo oil cooler adaptor with bolt $275
2 1/2 side exhaust end brackets  $95  pr
Export Brace - concours new equal bolt pattern  $175
Export brace angled re-enforce bracket weld to  cowl  $22
NOS Speedometer  160 MPH   $400
shipping not included
(920) 434 3645
SAAC Concours Chairman
