65 427 Center Oiler Short Block
Started by rolly11, September 04, 2019, 08:07:16 PM
rolly11
I just picked up a 65 Center Oiler 427. The motor had 61 HiPo 390- heads on it and tri -power. It was a good  running engine when I bought it two weeks ago. I tore it down to the short block to see how it looked. It is a standard bore with 427 low riser pistons and rods. The crankshaft is a 63 390. The block has never been broke or repaired and has very low running time on it. I believe it will clean up standard as there is no ridge on the top of the cylinders. The cast date is 5B9 $3500.00 plus shipping e-mail me for more pictures. r17531@comcast.net
I also have a complete 1964 406 std. motor complete from the tri power to the pan, distributor to the flywheel $7000.00 , a 69 428 C.J. motor complete rebuild  $8000.00, a Micky Thompson Cross Ram with the AFB carbs and linkage $1200.00 .
