Tail light lens restoration recommendations
Started by jswoody, September 07, 2019, 05:04:34 PM
jswoody
I am looking for recommendations on the restoration of the 1967 plastic tail light lenses.  My originals are in pretty good shape, but do not want to ruin them with the wrong process.  Any help is appreciated.
Quote from: jswoody on September 07, 2019, 05:04:34 PM
Buy the nice epro would be my recommendation. If the original looks distressed in the very least after reconditioning it will look worse then the current repro . Time ,money and effort has to be carefully considered when Trying to restore  originals. Once installed it is very hard to tell the difference.
557
Quote from: Bob Gaines on September 07, 2019, 05:35:34 PM
.   Who makes the nice retro's?
CSX 4133
For light scratches and discoloration a quality plastic polish can work wonders.
68blk500c
best product I have found is Blue Magic polish, which is really a rouge (extremely fine); metal or plastic.
Quote from: 557 on September 07, 2019, 07:31:44 PM
I don't know who makes them however NPD sells them.
BajaBroncos
I've taken original lenses to a detail shop and had them buff them out.  As long as they aren't cracked or faded, thats what I'd recommend.
Brant
-Brant
Are the repops correct color red? The 68-70 version is way off
BajaBroncos
Repops look nice in the picture on the web site.  and says they are the correct color.... not bad, I just prefer original parts when possible.  To each their own.
Quote from: BajaBroncos on September 12, 2019, 08:59:15 PM
Hey if you can find the originals that look new or can be polished to look new then great . I would always rather use a original part all other things being equal. I just wanted to point out that unless you can get the original to look perfect then the repro is typically a more viable alternative in this case not to mention the time ,effort and money to bring the original back to as new. Sometimes you can't tell if the effort of restoring the old lens will pay off until after you have put all of the time ,effort ,and money into the project only to end up with a less then new look. If you succeed the best you can hope is to match the as new look of the repro in this case. FYI the repro is made better in that the plastic of the flat lens portion is thicker which helps keep them from cracking like is common on the originals. You can tell the difference in thickness if you exam them closely while holding them however once installed you can't tell and you have the advantage of typically longer life.  All other things being equal I believe most people would rather see a new looking lens on a restored car compared to a less then new lens on the same restored car.
Quote from: Bob Gaines on September 12, 2019, 09:23:02 PM
I appreciate knowing that some of the reproduction parts are decent alternatives.
jswoody
Thank you for all the information.  Very helpful.
