Repo KH 15x6 steel wheels
Started by 6s1802, September 08, 2019, 11:38:41 PM
6s1802
Can someone, post a picture of these repo KH wheels?
Greg
I don't have a picture but call this number 812-273-4343 and ask for Jack.  He makes them and I believe he can send you what you need.
Shelby's and Fords from Day 1
KDunne
Quote from: Greg on September 09, 2019, 05:24:50 AM
I called that number....no answer
Wrong number. Jack's number is 812-265-4342. Wheels are similar but far from correct
acman63
I had some of the 15 x 6 inch versions made special order for us.  took 4 months.  Tim is correct.  they are OK  but the indents arent as pronounced and the center hole is larger.  They are also welded together if you are looking for riveted-  good luck.   I have to take them to get steelbrated  to remove all the imperfections prior to painting. Then epoxy primer black prior to painting the champaigne gold metallic.   Ive been retailing them for $475 a wheel painted.  The top picture is painted.  the other two are bare steel fresh from getting steelbrated  (920) 434 3645
SAAC Concours Chairman
6s1802
