Marking your HiPo Harmonic Damper
Started by NC TRACKRAT, September 16, 2019, 03:48:39 PM
Quote from: kjspeed on September 18, 2019, 10:26:50 AM
So you SUBTRACT .006" for aluminum heads and ADD .002" for cast iron to the cam card "hot" lash settings?
Yes.
kjspeed
Great info, thanks Doug! I wouldn't have guessed that there would be a .008" difference between aluminum and cast iron heads.
Also, just to clarify, would these adjustments apply equally to an FE or 289/302? And for flat tappet as well as solid rollers?
1968 Shelby GT350
1968 Mustang GT S-code
2009 Mustang Bullitt
Drew Pojedinec
Quote from: kjspeed on September 18, 2019, 10:36:05 AM
Not Doug, but clearance is clearance.
You can always recheck hot to see how much it has changed if curious. Valve lash can be a tuning tool as well (although a fairly minor one)
Gets real interesting setting up an aluminum block, aluminum head engine 😂
