289 valve stem seals
Started by red66, September 26, 2019, 07:56:08 PM
Quote from: gt350hr on September 30, 2019, 10:27:50 AM
The entire automotive industry has migrated to valve stem seals that press onto the valve guide in some fashion. While rubber umbrella seals "were" the norm , time marches on.
What you did fail to take into account is that you can't run performance springs without changing to positive seals. If you have a trailer queen that is being left completely stock, by all means use the umbrella seals. FEs tend to wind up with a puddle of oil up top if you don't restrict the oil to the rockers. If you have the heads off, install positive seals. Few reassemble heads with 50+ year old valve springs.
