help needed for location of speedo cable in firewall
Started by tonys_shelby, October 03, 2019, 06:51:50 PM
tonys_shelby
Can anyone send me a picture of where the speedo cable goes thru the firewall on there GT500 4 speed car? I had the firewall replaced and I think the aftermarket one didn't include the hole for it.
See attached, hope this helps...
(all standard Ford Mustang holes would think they are on a repro panel)
Quote from: JD on October 03, 2019, 07:22:22 PM
So sad to hear the use of a repro in this case given they are typically so poor. They are typically good for use to cut pieces from to do repairs but for others reading the use of a entire firewall  typically gives less then satisfactory results. Missing holes is just one typical symptom , definition in the stamping and other dimples and clip tangs found on originals will not be found on repro. Just my observations others may have a different opinion.
tonys_shelby
That does help thanks JD.  I'll check tomorrow but I think it looks like from the picture they are there but just sized way wrong.  I can fix that fairly easy if that's the case.  Yes original would have been a better way but it was so hacked up all ready from previous repairs and rust there wasn't much fixable.  Thanks again for help everyone.
Quote from: tonys_shelby on October 03, 2019, 08:23:31 PM
The tool that adds the dent pull tab can be used to add the missing tabs for the wire straps on the firewall.
tonys_shelby
That's a great tip Bob thanks.  The hole that I missed after seeing JD's picture was the clutch rod hole.  After close inspection there was a knock out for it that just needed punched out so now I'm good.
