1967 GT350 Upper Radiator Hose
Started by Shelby_r_b, October 10, 2019, 07:27:31 PM
Shelby_r_b
I believe this was discussed on forum 1.0...
The concourse correct upper radiator hose put out by Marti Auto Works seems to be a bit short. Also, the upper bend by the top of the radiator is more gradual (most likely due to the shorter length) then the almost 90 degree bend of the originals.
Has anyone else run into this issue? If so, how did you resolve the issue?
Thanks!
Nothing beats a classic!
I solved the problem by finding a good supply of genuine 67 upper hoses. PM me if someone needs one.
greekz
Quote from: Shelby_r_b on October 10, 2019, 07:27:31 PM
Thanks!
I had the same problem several years ago.  I called them and told them the radiator size, I believe 20", and they sent me the correct hose that fit perfectly.
Greek
SFM 6S1134  '67 GT-350 #2339
Shelby_r_b
Quote from: Bob Gaines on October 10, 2019, 07:33:41 PM
PM sent
Shelby_r_b
Quote from: greekz on October 10, 2019, 07:37:35 PM
Thanks!
Greek
Awesome! Thanks Greek!
greekz
You are welcome!  Check your radiator measurement because my memory is not as good as it used to be.
