'67 Oil Pressure Sender Extension ?
Started by oldcanuck, October 19, 2019, 11:04:57 AM
oldcanuck
It appears that I have a bit of seepage at one of the ends on my extension.
I was going to remove and either reseal, or replace, until I saw that my oil pressure sender appears not to be connected by an electrical wire, but what looks to be a very small id plastic line. I'm assuming a small vac line.
Please educate me as to what I am looking at, and how best to deal with it ?
Thank you in advance.
Bob
Bob
Knoxvegas, TN
Yes the plastic tube runs to the under dash gauge.  That extension on the engine block provides for the tube.
The standard Ford oil pressure sending unit was not used on '67 Shelby's and the wire that ran/runs to the sending unit on the Ford set-up is cut back up near the top forward end of the drivers' side valve cover.
oldcanuck
JD,
Thank you for the information.......
Is there a special way to remove/install the sending unit on the extension.... or the tube ?
Thanks again,
Bob
Bob
Knoxvegas, TN
Quote from: oldcanuck on October 19, 2019, 03:47:22 PM
JD,
Thanks again,
Bob
There is not electrical sending unit. It  It is a screw in steel adapter for a compression fitting and nut. A clear plastic line runs to the mechanical gauge under the dash.On a GT 500 it only goes on one way . The GT350 extension can be rotated . Basically It is best to have the pipe thread opening on the extension clocked so it points as close to vertical as reasonable. On a regular Mustang this was accomplished by orientating the electrical sender /extension assembly at a + or - angle specified and illustrated in the electrical assemblyline manual that you should have  ;) if you plan on working the cars with any kind of degree of historical accuracy.
oldcanuck
Thanks Bob..... kinda what I thought. Does the plastic line become brittle/fragile with time ?
I'm assuming I need to be very careful with it........
Bob
Knoxvegas, TN
Quote from: oldcanuck on October 19, 2019, 06:44:34 PM
Yes ,especially if you have the original one . 50 years does a number on the plastic.
  It is Stewart-Warner brand plastic line.
Quote from: roddster on October 21, 2019, 03:28:22 PM
Some were marked as such most were generic looking with no markings.
oldcanuck
If I somehow mess it up, can the plastic line be sourced ?
Bob
Knoxvegas, TN
Quote from: oldcanuck on October 21, 2019, 06:32:37 PM
Certainly . It comes in a typical generic mechanical oil pressure gauge installation kit. You can buy the installation kits separately . Jegs ,Summit ,Orielly's etc.
Quote from: onelimegold on October 23, 2019, 10:59:45 AM
SW NOS kit looks like this .
Even though the discussion is about the plastic tube I wanted to point out the fittings. The SW installation kit was included with the SW oil pressure gauge used in a 67 Shelby. The installation kits ether SW or other more generic variety typically come with attaching hardware. Unlike most generic hardware kits which typically consists of brass fittings the fittings that came in the SW installation kits were a non typical zinc plated steel. Also the one piece steel fitting for the engine side is different in shape from the typically 2 piece brass generic fittings .  FYI brass will readily plate with zinc for a appropriate historically accurate look. So if the original steel fittings are not readily available zinc plating the brass fittings is the next best alternative IMO.
Notice the plastic line in the NOS SW kit pictured is of the more typical unmarked variety.
This is hose from an SW hose kit dated 11-4-67.  The hose is marked in this case.
        -Keith
