1968 Shelby console for automatic on C/L
Started by OldMil, February 22, 2018, 04:22:07 PM
KR500
69mach351w
Quote from: KR500 on February 22, 2018, 05:43:56 PM
It is a reproduction, Not an original.
Ok, KR500 tell us why. Share the knowledge. You know some of us are not-so-knowledgeable.
QuickSilverShelby
The Ashtray is wrong and the cobra doesn't look right.  The insert has no fuzz on it and there's probably ten other things that Pete or Tim can point out.
QSS
thefordshow
 I would add that the Woodgrain is modern 3m walnut, filler insert above the two gauge holes is wrong, should be a special foam edging not vinyl wind lace, wrong light lens in the glove box liner.
KR500
Quote from: QuickSilverShelby on February 22, 2018, 08:57:26 PM
+1. Plus hardware is wrong, latch and more.
69mach351w
Thanks all.  Good to share information on the forum. Although most would've knew, a lot of us still like to learn.
