1967 Mustang GT disc brake distribution block fitting
Started by Horsman, November 06, 2019, 09:16:44 AM
Horsman
Need the fitting that screws into the front of the distribution block that attaches the left front metal hard line. See attached pic.
Thanks in advance.
I don't think I have ever seen one sold separately or for that matter seen one separate from the distribution block in any context other then a rebuild of the distribution block.Not to toot my own horn but I have seen a lot. I would probably miss it unless it was close by the block to associate the two.  With that said you may want to purchase a complete one so as not to stall your project. NPD still has them in their 2019 catalog for 85.00 . I am not sure if they still stock them . I know the 65/66 version in their catalog has been discontinued. From my perspective I wouldn't waste a lot of time trying to find the separate fitting. I hope you are lucky and find it but I think the odds are against you just saying.Best of luck with your search which ever way you choose to proceed.
Horsman
Yes Bob, I agree its a longshot. Maybe someone on the board has a parts car with one on it. My car had a line lock, therefore the brake lines and attaching fittings were a mess(see pic). I accidently chunked that fitting thinking it was part of the cobbled mess...oops.
Quote from: Horsman on November 06, 2019, 12:32:05 PM
The problem is that it is not to the advantage of the seller to separate the fitting from the distribution block . One is not any good without the other . At least if the the seller is knowledgeable about the part. I just hated to see a project held up by having IMO a unrealistic expectation of finding the part separate.  I suppose it is worth a try. Stranger things have happened.
