Hertz carrier housing
Started by MHz, February 24, 2018, 10:23:11 PM
MHz
How do I identify a carrier housing and pinion retainer for a mid-February Hertz?
Ross
Blue Hertz, Metke Ford, Seattle
Shape and features along with date codes of the case and the pinion retainer.
Do you have one that yours asking about  (if so much easier to post a couple of pictures)  or are you looking for a guide for the hunt?
acman63
start to make sure its a 9 inch.  easiest way to tell in the car is whether you can get a deep well socket on the bottom two bolts.  If you can its an 8 inch .
2nd is whether it has a plug in the side of the casting, since the axle tube itself has a plug. it will not be drilled and tapped for a plug. 3rd  If you can read the date code on the case it should jive with the rest of your parts as well as the bearing retainer which should be able to use the bolt on steel rebound plate.
as for the driveshaft pinion yoke.  thats another issue and with out a picture its hard for me to explain
SAAC Concours Chairman
DennyD
Here's a couple photos of Jan 66 dated housing and pinion support. Your's should look the same as these. Denny
MHz
I need to find one. Car currently has a WAR unit in a '65 9" housing.
Ross
