1967 Shelby GT350 Oil Pressure Line
Started by Shelby_r_b, December 09, 2019, 09:34:04 AM
Shelby_r_b
I understand that the oil pressure line (the one running from the block to the under dash gauge pod) was clear plastic on the early cars.  Did this stay consistent through the 67 model year, or did it (the material) change over time?
Thanks!
Nothing beats a classic!
Shelby_r_b
  I sense an underlying question, so:  No, they never used copper.
Shelby_r_b
Very astute, Rod :)  I had heard that some cars have had hard lines installed, but I wasn't sure if that was an aftermarket add or if some came with a hard line.
Thanks!
Quote from: Shelby_r_b on December 09, 2019, 11:05:45 AM
Thanks!
Copper line is a somewhat common aftermarket replacement for the original plastic line used throughout 67 Shelby production.
JWH
If you check e-Bay, you will find a number of Stuart Warner kits available with the nylon tubing.
Bob G, if I recall correctly, there is something specific about the fittings on the '67 Shelbys? They were steel not brass or something like that? Will you please help and let us know what is correct?  Thanks
Quote from: JWH on December 09, 2019, 04:26:06 PM
Yes the fittings were plated steel and not made of brass.
DGSOH
Also available from places like Summit Racing: https://www.summitracing.com/parts/SWW-366HM-F
  I meantioned the "no copper" because - over time (short time) the copper cracks and then leaks all over.
