68 GT500 Fan Shroud
Started by Milo, January 05, 2020, 08:05:05 PM
Milo
Looking for a replacement original fan shroud for a 68 GT500
Thanks!
Milo
1972 Bronco Coyote
1968 F-250 Camper Special 390
Bigfoot
Are all 68 Big Block fan shrouds the same?
If yes,....should be easy.
I think yes but will let experts chime in.
RIP KIWI
RIP KIWI
Quote from: Bigfoot on January 05, 2020, 09:41:13 PM
Not all of the same . The assemblyline version is the hardest to find and the most expensive to buy typically. The part evolved over the years into different versions. Check out this link to very good pictures and explanation of each. https://www.428cobrajet.org/id-shroud .
DC-DD
I believe I still have a revision C version that I will sell if anyone is interested.
Original style and look not the later plastic looking one.
cushmancomp
Quote from: Milo on January 05, 2020, 08:05:05 PM
Thanks!
Milo
C8ZE-A is the assemblyline version any others would be a replacement for the original.
8T03S1425
The number that Bob is referring to is on the left mounting flange just below the upper mounting slot.
Steve
I owned 6S2295 in 1973 & '74.
Milo
Thank you for your wisdom, Bob! I'd never have thought to dig any deeper, outside of knowing I wanted a 'horse hair' version. Ill have to go dig up the many, many pieces of my original to see what tales it tells me...
Quote from: Bob Gaines on January 08, 2020, 04:36:52 PM
Thanks!
Milo
1972 Bronco Coyote
Bigfoot
Reach out to DC-DD if he still has his.
The "A" shroud was serviced with the "C" and you will likely never see an "A"  available in good condition .
RIP KIWI
RIP KIWI
CobraJetSet
I have an NOS horse hair shroud. Message me if you need one. Thanks
PR
There is an nos one on the 428 cobra jet forum 1100.
CobraJetSet
Milo, I PM 'ed you with contact info. Thanks.
