Ebay: Vintage HONE O DRIVE OVERDRIVE UNIT
Started by BGlover67, January 18, 2020, 11:07:25 PM
   "IF" you only use it as it was designed for, it does it's job and is a unique accessory.. That being said , "modern" units that bolt onto the transmission are superior and less troublesome.
Do any of the modern units, and that, (I assume Gear Vendors is the only one), activate with mechanical linkage like the Hone?
I know Gear Vendors rates theirs for huge power too.
Quote from: 2112 on January 20, 2020, 03:11:37 PM
Don't believe so - ran a Gear vendor on a F350 about 10 years ago. All electric control
     Gear Venders is an American (?) copy of the Laycock overdrive units.     ;)
Quote from: J_Speegle on January 20, 2020, 03:30:19 PM
+1  all electric and smooth as silk. I have one on my F350 race car hauler and wouldn't leave home without it LOL.
Do you push in the clutch when shifting into overdrive?
 You can or just "wave" the gas pedal. I have an automatic and do the latter when I manually hit the switch. I also have an "auto" function that makes it feel like a factory AOD , but I rarely use it.
Couldn't do it. Too many unknowns on the unit itself.
Quote from: 2112 on January 21, 2020, 09:17:54 PM
Keep in mind that you have to pop a hole in the tunnel and carpet for the lever used to engage/disengage action.
Was the Hone-O-Drive ever available for purchase through SAI?  Did SAI ever issue it a part number?
Quote from: silverton_ford on January 29, 2020, 10:49:55 PM
I don't remember seeing it other then a stand alone advertisements. I just checked 11 different SA and Ford high performance parts catalogs from the 60's and early 70's just in case and didn't come across anything. If it was it was obscure.
Here are a couple of ads run in period magazines
Thank you Bob and Jeff.   I also looked through all of my parts books and catalogs and came up empty.
    Being a "local boy" I can assure you the Hone OD was NEVER run in 5S360 as pictured in the ads. That car ran low 12's and would have dropped the Hone out on the track with Don's driving style. "On the floor and dump the clutch" was not safe with the Hone unit  because of the added weight "hanging" on the front of the standard grey iron housing and the increase in leverage ( against axle rotation) . I know from "customer experience" on a guy I built one for in '69. 4.57 gear ratio , wamed over 289 , 4spd and slicks. With two runs on it , there was "a clean up on lane one " LOL Hone laughed at me when I asked about a warranty , but happily SOLD me replacement parts. My customer never drag raced the car again. He switched to road racing and the unit lasted beyond his sale of the car.
     We ran the Hone in the '70 Shelby for "street" use, which was particularly appreciated with the 4.88's,  but it was always removed for the drag strip, as the 427 T.P. had proven it would rip the guts out of the O.D. given the chance.
     Back in them there days, I could the swap the 9" center in twenty minutes, and that was without air tools!      ;)       I'm a little slower now.       :-[
