Small block steering shaft vs Big block
Started by BGlover67, January 20, 2020, 09:54:42 PM
BGlover67
Did all Big Blocks have rag joints and small blocks have solid one piece shafts, or was it an early/late thing?  What's the final thought on this?
Brian R. Glover
Quote from: BGlover67 on January 20, 2020, 09:54:42 PM
Big blocks typically had rag joints. After approximately May 1 67 smallblocks did too.
JWH
Here is a reference on the boxes with some background and decoding of steering tags:
http://www.stangerssite.com/steeringboxtagdecoder.html
  And any car ordered with the tilt wheel option AKA " the T-bird option" would have the rag joint.
Currently conduction a survey and research on the subject but have collected a fair amount of data from late cars and excluding tilt cars (survey covers only Mustangs and Shelby's built at San Jose in 67) the solid steering columns were installed through out the complete production years to the last days before changing over to 68 production.
Just what the facts/data shows so far.
Quote from: J_Speegle on January 21, 2020, 06:12:16 PM
Thanks Jeff.  I had not seen any rag joint late '67 GT350's but you've seen more than me!!  I think (?) #3002 did not have a rag joint.
Quote from: JD on January 21, 2020, 06:20:40 PM
Just another example of the Ford MPC not being always right.
Being the reference was to big block cars. Yes. They all have two-piece columns with the rag joint.
