radio delete
Started by 65Clone, March 01, 2018, 06:32:53 PM
65Clone
Do 65 and 66 radio deletes look the same from the front, or do they differ somehow other than the part number on the back? Picture of a 65 vs 66 would be great, if they look different.
papa scoops
they are different. the upper dash pad drops down farther on one year (around the radio area.) phred
texas swede
They are different. The 65 type has sharp upper corners while the 66 has
rounded upper corners.
Texas Swede
And if you try to install a 65 into a 66, you are going to have issues and it will not look right.  I am not sure if it can even be installed without big interference's with the dash pad.
You can easily install a 66 into a 65.  You will have to decide if it looks good or not.
65Clone
Thanks for the quick answers, this is exactly what I was looking for. Picture is worth a thousand words, even when the words are all correct. Thanks again. :)
