RUG-S TOP LOADER 4 SPEED
Started by a4278v, March 01, 2018, 10:07:50 PM
a4278v
I just wound up with a very nice short, big in & out RUG-S nice shape but missing the tail housing and there seems to be 2 options  a C60R-7A040-C or C7OR-7A040-A which would be correct? thanks in advance for any help Bruce a4278v@yahoo,com
Since you are in 68 I'll assume its a 68 RUG S, is it early or late?  Most will be the C7
a4278v
I  got this trans with a load of others and have no history on it there is a really faint  unreadable number stamped on the top of the case
cboss70
The experts here can correct me but the RUG-S was also used in 1967 so the C6 tail could work if you plan to use it as a 67 trans and the C7 could work on a 68. What I cant answer for you is around what Shelby serial number in 1967 did the tailshaft go from C6 to C7 (example did #2700 and above use a C7?).    Which one you use would depend on at year and Shelby serial number.
a4278v
Greg
I believe the C6OR-7A040-D is the correct tail shaft.
Shelby's and Fords from Day 1
Fast Fords
Is the RUG S also used in the 68.5 CJ Mustangs along with the Shelby's or just the Shelby's? Thanks.
cboss70
Yes, it was in some of the big block mustangs also.
Quote from: Fast Fords on March 02, 2018, 12:29:13 PM
not sure about 135s but regular production cjs got RUG AE and very late cars could have AE 1. For the original post like I stated in first reply, tail shaft for 68 RUG S could be either C6 or C7. On main cases 67 cars would have C5 and 68 would have C8.
Another little known factoid, C7 tail shaft can be either small or big output with same casting number. Big out machined differently
a4278v
a4278v
#10
 just came back from the storage area and  determined that the stamped # on the top ear is 135054 I guess this may be a pretty significant piece to someones puzzle  does this change what # tail housing it gets?
a4278v
 from what I  can tell this is from The Russ Davies Gas Ronda car>>>???
69mach351w
Wow, you've got a 135 tranny!  And I might say, could be a pricey piece!
This might be of interest:
https://www.428cobrajet.org/8F02R135054
