Stewart Warner 240A fuel pump
Started by mlplunkett, January 30, 2020, 11:38:43 PM
mlplunkett
Anybody have some photos and info on how the electric fuel pump is mounted and plumbed in the R model? I'm also looking for a source for a rebuild kit for the 240A.
TJinSA
Rebuild kits were being sold on fleabag
Tom Kubler
6S296
Quote from: mlplunkett on January 30, 2020, 11:38:43 PM
Drew Serb of the Cobra Experience is a well known rebuilder and parts supplier of those . I assume he still does them.  If you have one now and If you put power to the pump and it doesn't do the thump thump thump noise or if it only makes one thump  that means the internal switch is bad. It is easier and less expensive to buy one that already makes the pumping sound and re seal and re gasket that one that the switch still works in. The switch has been obsolete for decades know and when you find them NOS they are expensive. There are people who have been successful rebuilding them (not me) but again expensive.  I have been buying ,selling ,using and rebuilding them off and on for a number of years now and that is what I have found to be the case . Hopefully others have had better luck then I.
   I have seem them mounted to the bracket for the trunk hinge on the driver's side.
gt350bp
I'm also looking for detailed photos / drawings of a Stewart Warner 240-A fuel pump installation in a R-Model. Would also like to find a Stewart Warner 240-A installation and parts drawing if available, as a friend gave me a pump to use in my car.
Thank you.
Don
gt350bp
SFM5S000
Quote from: gt350hr on January 31, 2020, 10:26:07 AM
Randy,
That would be the more common single SW240A unit mounting arrangement. It had issues being up so high. I have SAI photos somewhere of the single plumbing arrangement and the passages where it enters the underside and connects to the long range fuel tank fuel pickup. The point of entry for the dual is similar.
The previous image above that Bob G. posted is the dual SW240A mounting from 5R098. I took dimensions of that bracket years ago and installed it in my 65. Here it is:
SFM5S000
Mickey,
I so happen to have a full set of the re-Build kit from SW. What is it you need?
~Earl J
SFM5S000
#8
Quote from: gt350bp on February 01, 2020, 12:45:46 PM
Thank you.
Don
gt350bp
Don,
I have the SW service instructions...I found them. (some may be duplicates)
~E
SFM5S000
SFM5S000
SFM5S000
#11
The switch...a lot of time the pins can get crud build-up and cause it not to work.
~E
gt350bp
SFM5S000, thank you for the Service Instructions. That is exactly what I was looking for! This is very helpful, now all I have to figure out is how to print them, as when I try to fit them to a page, I lose all print quality and they are not readable?
jamesfee
First a *huge* thank you to SFM5S000 for those detailed docs. I am very grateful for your efforts. Just one lurkers opinion.
To gt350bp - I  expanded the images (one at a time) copied and pasted them into a directory - renaming them SWpump1.jpg thru 11. By printing them as full page pictures, I get around a 5x7 service instruction that is readable and can probably expand that if necessary.
j
6S1801
gt350bp
Will give that a try. Awesome information and thanks again.
Don
gt350bp
