1969 gt350 valve cover gaskets
Started by musclecarman15, February 20, 2020, 05:43:41 PM
musclecarman15
Does anyone know what brand valve cover cork gaskets line up with valve cover tab cutouts. Thanks keith
Quote from: musclecarman15 on February 20, 2020, 05:43:41 PM
What most have been doing for decades is if you can't find ones with tabs that lines up with all of cutouts is to use a donor gasket to cut tabs off of to glue on the ones used for valve covers or make extra tabs out of donor gasket remnants .
musclecarman15
Bob,the tabs on regular steel valve covers line up but on the cast cobra valve covers all line up except the 2 on the outside...with the felpro cork gaskets,I haven't found one that lines up with the cobra valve covers...is it possible I need to look at 289 gaskets? Thank you keith
Quote from: musclecarman15 on February 20, 2020, 08:09:15 PM
Hopefully someone will speak up with a gasket still available that has all of the tabs located where they need to be. Like I said myself and others have been doing what is needed to get the job done for more then a few decades now . I never gave it a second thought and made the gaskets look the part from what you can see given that is the most important aspect.
Quote from: Bob Gaines on February 20, 2020, 09:21:06 PM
........... Like I said myself and others have been doing what is needed to get the job done for more then a few decades now . I never gave it a second thought and made the gaskets look the part from what you can see given that is the most important aspect.
+1
After I gave Keith the OP a lead provided to me by another forum member he let me know that he had just received a set of cork gasket ordered from NPD and ALL the tabs are there and line up perfectly.
musclecarman15
bob,just wanted to say thank you for your due diligence...i always appreciate the extra efforts people on this forum help each other....keith
