Cobra emblem dimensions
Started by 68ShelbyKR, February 22, 2020, 03:53:09 PM
68ShelbyKR
Can someone please give me the exact dimensions of the Cobra emblem that is on the fender of a 1968 Shelby GT500 KR?
Thanks in advance.
"These cars are meant to be driven", so enjoy the hell out of all of it - not just the look of it when it is all clean" - Carroll Shelby
I've always been asked, 'What is my favorite car?' and I've always said 'The next one.' - Carroll Shelby
68ShelbyKR
Thanks Coralsnake, however the link only shows placement.
I am looking to by a pair of the Cobras and want to confirm they are the right height and width.
Take care
There is only one size if you buy the correct 68 snake.
The one in the photo does not appear correct
The side stripes on the picture you posted are different from the OEM stripes, just an observation
The snakes should be the same on both sides (no left and right)
68ShelbyKR
So the passenger side would face towards the front of the car and the drivers side would face to the rear, correct?
And the ebay listing you put down would be correct OEM?
I am attaching a pic from Scott Drake, is it correct OEM?
No! ..the snake never faces to the left as you look at it
Just assume all the Drake stuff is incorrect and you will be fine
The link I posted has the correct snakes, much different in appearance
In your first photo, there is no way to tell if that is left or right side of car. That orientation is correct for both sides. (as it should be)
I suspect the Scott Drake picture has unknowingly been reversed .
68ShelbyKR
the Scott Drake parts are not correct for a 1968.
The F6ZZ part number indicates those are for a 1990s vehicle
The originals are not plastic
68ShelbyKR
Thank you.  I talked to them this morning and they didn't mention that.
Here is one that states it is NOS for 68-71.  But the snake definitely looks different on the horizontal scales on the front.  They appear to have "texture" or vertical lines rather than smooth like the Cobranda cobra.
https://www.ebay.com/itm/NOS-1968-1969-1970-1971-FORD-FAIRLANE-TORINO-SHELBY-COBRA-METAL-SNAKE-EMBLEM-NOS-/143536273343?_trksid=p2385738.m4383.l4275.c10
68ShelbyKR
Here's one that claims to be factory correct also.  Apparently I have a large learning curve ahead of me!  ???
Those look correct
There is a version that is not flat, when you lay it down for 1969
The 68 snake is flat
